N
Noddy67
Hi,
generally speaking if a afluorescent light isn't working is there any quick way of narrowing down the problem between the starter, the tube and the ballast/choke. Apart from changing starters and tubes (and i can't carry the latter around on the off-chance) is there a way of testing each component on the regular multi-meter or similar?
I'm not talking about any particular fluorescent here, just in principle.
thanks in advance.
R
thanks in advance.
R
