Fluorescent Ligting | on ElectriciansForums
Discuss Fluorescent Ligting in the Australia area at ElectriciansForums.net
H
hutch6447
Hi, touching fluorescent for the first time and just want some confirmation on the wiring to get two way lighting now the problem is coming as there is only Line, Neutral, Earth on the fitting so where does your switch lead come in to play, pretty happy with the wiring to get the next switch in just the wiring from the garage consumer board to the light to the first switch. Many Thanks
If there's only L, N and CPC at the fitting it's the last one on a looped row. Two way switching goes from switch to switch, it has nothing to do with the cabling arrangement at the light.
If you're struggling to wire this you should stop what you're doing
Yeap everything fine just couldnt remember from my NVQ 3 days just had deep thought time and i remembered the 2 way switching of switch feed. I now have nice two way lighting thanks guys.
Reply to Fluorescent Ligting in the Australia area at ElectriciansForums.net
Firstly I would suggest that of the three sets of cables, they are not all 'incoming'. There might be one cable (of 3 wires) bringing in permanent...
Often in old wiring, live to the downstairs switch, then in twin (or twin & earth) the two switched lives to the upstairs switch, and a single...
