Fluorescent to LED conversion tombstone removal | on ElectriciansForums
Discuss Fluorescent to LED conversion tombstone removal in the USA Electrical Forum area at ElectriciansForums.net
Sammamish, WA
I have about 30 4 bulb 4ft shop lights that I want to convert from fluorescent to LED. I need to swap the tombstones from shunted to unshunted on one side to do this. I can’t for the life of me figure out how to remove the metal tab that the tombstones anchor in to. There are no tabs on it to use a screwdriver. Outside of drilling my own tabs into it is there something I’m missing? Thanks in advance
[ElectriciansForums.net] Fluorescent to LED conversion tombstone removal
You beat me to it just sussed it :)
Those points you have arrowed look spot welded.
[automerge]1567439534[/automerge]
I suspect that fitting is pretty maintenance free aside from the control gear cover. Can you show a pic with the tubes removed.
I have about 30 4 bulb 4ft shop lights that I want to convert from fluorescent to LED. I need to swap the tombstones from shunted to unshunted on one side to do this. I can’t for the life of me figure out how to remove the metal tab that the tombstones anchor in to. There are no tabs on it to use a screwdriver. Outside of drilling my own tabs into it is there something I’m missing? Thanks in advance View attachment 51848
Collab take the bulbs out then take your hand pinch both sides and it should come right off. Turn power off
Reply to Fluorescent to LED conversion tombstone removal in the USA Electrical Forum area at ElectriciansForums.net
For my hapeneth and learnt from hard recent experience, the term LED transformer and driver tend to be used interchangeably, when they are...
USA Electrical Advice
Welcome to the USA Electrical Forum at ElectriciansForums.net. The friendliest electrical forum online. General electrical questions and answers can be found in the electrical forum.
This is the main UK Electrical Forum at ElectriciansForums.net. Electrician Laws and Regulations related to Electrics and Electricals within the United Kingdom. Electrician talk, questions and answers can be found in our UK electrical forum.
