davelerave
fitted 4 'alaska' brand 5ft twin corrosion proof w/magnetic ballast and T8 tubes last week
supplied by CEF
everyone of them seemed to be faulty-take off the cover or give them a tap and they'd come back on
eventually i put it down to the end caps-voltage was ok and i don't think it was the cold
just wondering had anyone a similar issue
also was wondering what sort of temperature the corrosion proofs are reliable at
afaik the electronic ballast fittings are more reliable at low temperature?
thanks
5-footers with conventional ballasts are generally ok starting at low temps, it's the 6- and especially 8-footers that struggle.
T8 lamps will take a while to reach full brightness
As you say, likely poor quality end caps.
Were the tubes aligned correctly? Not all of them have an index mark for the rotating holders.
Electronic ballasts can be more reliable - just check the spec for minimum strike temperature - not all of them go below freezing!
Simon.
fluorescent troubles
Australia
davelerave,
davelerave,
