fluorescent tubes | on ElectriciansForums
Discuss fluorescent tubes in the Electrician Talk | All Countries area at ElectriciansForums.net
Reply to fluorescent tubes in the Electrician Talk | All Countries area at ElectriciansForums.net
Thanks very much for your kind suggestion. Really - it is most likely to do with a very flimsy cold-cathode-start inverter, as the tubes barely...
Is the new tube identical to the old one ie same voltage, same wattage output etc? Can you post a pic of the writing on the old tube as well as...
Thank you for your quick and excellent response - I hadn't thought about the cables changing over time. I'll replace all three. Thank you once...
Hi, I am restoring an old art deco, wall mount medicine cabinet. The cabinet has an 18” fluorescent light tube on each side. Before I put a lot...
You really need an inductance or LCR meter or a ring tester which are expensive to buy but you can make your own ring tester if you want a project...
