O
One_of_them
Hey fellas,
Lighting circuit protected by 10A MCb feeding some fittings in an office. Supply 1.5mm T&E loop in through ceiling roses, flex down to suspended fitting and terminated into a choc block internal of fitting. Out of this choc block is the fittings internal wiring consisting of 0.8mm solid core cable which goes into the ballast. Same wire (but white) coming out of ballast to end caps.
My question is....should these fittings be locally fused to say 3A as the 0.8mm coming out of the choc block is in theory protected by the 10A MCB back at board?
I hope that makes sense and somebody could clear it up for me. Reason....removed some old fittings which WERE fused and fitted new ones which are NOT. I was told some fittings do not require it, is this correct?
thanks in advance
thanks in advance
