P
Piratepete
Hi Guys
I'm often asked to replace a standard pendant fitting with a flush fitting having no compartment for connecting loop in/out and switch wires.
Apart from buying a fitting with said compartment, the obvious solution for me is to fit a 'Round 35mm Deep Dry Lining Box' in the ceiling first. However, all the ones that I've seen require an accessory with the correct hole centres to retain them, same as the rectangular ones used for sockets, light switches etc.
Is there one that has it's own retention screws/mechanism?
Cheers
Pete
Cheers
Pete
