Flush mounted enclosure for ring transformer | on ElectriciansForums
Discuss Flush mounted enclosure for ring transformer in the UK Electrical Forum area at ElectriciansForums.net
Dartlec
Kent
Had a quote today at a new build where they've not bothered to put any facility for a doorbell.
Customer has purchased a Ring Wireless Pro, which comes with it's own 24VAC DIN rail mounted transformer.
Given the location of the CU, it is not the simplest path for a cable run, so looking at other options, including mounting the transformer nearer the door. There are no handy cupboards unfortunately, so I'm looking at options to mount the transformer on the hall wall without it looking awful.
Protek do a 2 module din rail enclosure, but it's not the prettiest looking thing. A white adaptable box is an option I guess but again not perfect.
What I think I want is a small flush mounted enclosure with minimal protusion and/or a neat cover, but can't seem to find anything - anyone aware of one? The transformer is too deep to even put in a double 47mm backbox and blank cover.
I want to give them both options - trunking from CU and local mounting, then let them decide which they want to live with.
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
Bl**dy new-builds! I mean it's not as if they're cheap...but don't provide a doorbell, ffs! All too common, sadly.
Is there a possibility of making a "feature" out of the installation, like maybe a fancy wall-mounted light fitting with the transformer concealed behind it?
There is a light switch with neutral nearby so might be able to suggest that yes - Naturally all they've provided is pendants everywhere and even the one outside light is the wrong side of the door so not lighting the posh number sign :rolleyes:
move the posh number to the other side of the door.
I've had been looking at this issue in my new build for a Nest door bell. The provided door bell hasn't the DC voltage for the Yankie Nest thing. There are some third party plug in adapters for the Nest, perhaps there's something similar for the Ring.
No sockets in the room sized hallway either - at least not at the front end.. who would possibly want to plug something in by the front door!
A 6 months old house, Dual RCD MK board, and armoured cable feed to the garage coming out of the carpet about a foot from the wall and installation method of 'free air' to the board.... At least it's in a walk in cupboard I guess.
I wouldn't care what stage the build was at; if that had happened when this place was being built, they'd have been digging up floors to sort it and running a new cable if necessary. Never going to get perfection in a new build, but that's a bit more than a minor niggle.
The Electrical Contractor doesn't have the initials CE by any chance ?
What makes you think there is any paperwork that he would put his initials on?! (I didn't actually ask for the EIC, but I would put a significant wager on one not having been supplied, though it might exist somewhere...)
Thinking about it, do new builds have to comply with Part P notification? Nothing showing on the postcode so I assume not.
I‘ve a Nest cam out front, to spy on my neighbours. Comes with a long lead that plugs into a socket. Done it in such a way, you can’t see the lead. Sure you could.
Something like this
PS Why don't they get a refund on the Pro, get a Ring Video Doorbell 3 Plus which has a rechargeable battery pack. Then they wouldn't have to pay for your services. Just saying. :)
I was thinking more of a large company with those initials rather than a small concern or sole trader. I've seen some of their work, 1.5 SWA seems the norm for garage supplies and they have a knack of wiring DP switches with neons the wrong way round so the light stays on regardless. :)
Yes new build installations are notifiable under Part P !
Looks like it was not a national company, but a small one, though not local - knocked down one property in 2018 and put 5 detached ones up - the one I was looking at is apparently a 4 bedroom and when on the market was guide price of 550k :rolleyes: Really is a way to print money if you have the up front capital to fund it.
No Part P notifications that I can see, though not sure if there is a way to check all of them - If I go back I will investigate a bit further.
Though I almost always end up explaining it to my clients who have never heard of it before, despite having had electrical work done in the last 10 years.....
Reply to Flush mounted enclosure for ring transformer in the UK Electrical Forum area at ElectriciansForums.net
