Flush Mounted PIR | on ElectriciansForums
Discuss Flush Mounted PIR in the UK Electrical Forum area at ElectriciansForums.net
M
monkee
Morning all,
does any one else have problems with a sertain make flush PIR ( Danlers ) xs
is there another option it still gets effected by the wind
thanks...
Never heard of that before monkee, Danlers is a quality product, I have had lesser PIRs come on when heating in the room rises to the detector and customers complaining it comes on in the middle of the night, never heard of wind causing issues though, are you sure it is not just a one off faulty piece?
I recall having issues with these a few years back. Found the problem to be the BMS, some idiot decided to cut the control live to switch the lights off. This resulted in a whole host of symptoms, lights permanently on, lights not turning on, etc. Once we removed this, we reset all units, and most lived.
I remember thay came out with sealed unit then the extra sealed unit, if you look thay stuck a bit plastic ( tape ) around the rim of the fitting white on the face and black inside.
just put out to see if any one else had the same issues.
thanks for any feed back cheers guys
Reply to Flush Mounted PIR in the UK Electrical Forum area at ElectriciansForums.net
My bafflement increases. I swapped the offending light with one elsewhere on the back of the house - one of those that's on a circuit of its own...
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
