Q
qprfcmark
Hi,
About a year ago I replaced the blower switch on my 2001 Focus because it did not work on any of the 4 settings. When I removed it I noticed slight melting around the plastic housing.
The new switch has been in for only a year and as you can see from the photos there is extensive melting to the contact with the black and orange wire. What is causing this? A bad connection that is creating arching, a short or is the blower drawing too much current due to its age? Prior to me removing the switch it was working on the 0 setting!!!
