We are due to have our first NICEIC assessment and I have been asked to be the QS. Have I just accepted a poisened chalice? Looking at some of the completed EICRs I notice several differences in the way they are completed. We are using NICEIC style forms and the discrepancies are on Isolation and switching, and Switching off for mechanical maintenance. Some guys are ticking all the isolator and mechanical maintenance boxes, saying that the MCB is the primary source of isolation, whereas others are saying the isolators are the cooker switches, FCUs and light switches, etc. Also, on the max Zs permitted where the circuit is RCD protected some are putting the Zs as 1666, some 1667 and others as whatever the breaker is rated at. If the service fuse is sealed do we also put NV or LIM on the outcome and characteristics. If the seal is broken/missing I always noted it previously.
Any assistance/guidance would be appreciated. As the QS would I have to sample check the other sparks' works or do I spend a day alongside them when they are doing an EICR?
