C
Chrisr6
Hi folks,
I need some help with a motor control circuit for a reversible motor/pump.
This may be a very simple question with a very simple anwser so forgive me if it is. I know very little about this sort of thing so any help would be much appreciated.
I have been given the task of drawing a basic circuit with a forward reverse contactor with interlock & finding the appropriate one for the job. Its for a 3ph 2.2kw motor driving a reversible foam pump.
I hopefully understand correctly that both contactors cannot be operated at the same time because of the interlock & that the stop botton has to be pressed before you can engage the motor in the opposite direction?
I wondered if I needed some kind of time delay in the circuit of 30secs or so, to stop users going from forward, straight to reverse before the motor/pump had time to slow down & stop first? If so how/where in the circuit would it be incorparated? What kind of contactor/timer would you folks recommended if any?
I've found a few contactors in various catalogues & online, I've also found a few different time delays which only seem to allow the circuit to run for a short space of time before they cut the supply, so don't look suitable.
Many Thanks in advance, Chris.
