A
acowx
Hi All,
Just a quick one,
Im going to put a couple of lights down the bottom of my garden, the run is approx 20m and I have an adequate amount of FP 200, now SWA would be the prefered choice of many I understand, but having this cable im thinking of using it to do the run.
I was going to clip direct to my fence at about 6ft so theres no problems with mechanical damage (Ie - Spades, forks etc) and the cable is 1.5mm so no problems to run a couple of lights, (Cable calc done).
So really just wondering your thoughts, would you not use at all, put it in conduit or just fine how it is.
Obviously all terminations will be sufficiently IP rated.
Look forward to hearing your thoughts, thanks in advance.
Ashley
Just a quick one,
Ashley
