free standing cooker | on ElectriciansForums
Discuss free standing cooker in the Australia area at ElectriciansForums.net
V
villlayouth
whats the requirments when siting a fused switch for the spur for cooker,i noticed one today and it was directly above cooker,surly this wrong as the heat of the cooker could damage it,is there a distance it should be from cooker
Not sure if it is a regulation just guidance, switch for cooker should be 300mm away to avoid reaching over the cooker to switch off, should be less than 2m away so that it is local to the cooker if required. I think this is in the pretty pictures in the sparks guide to the building regs.
Reply to free standing cooker in the Australia area at ElectriciansForums.net
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
It is actually specified in BS7671 that the cpcs must be connected to all other sources of earth.
