Hi,
We have a ten year old fridge-freezer plugged into an older socket (20 yrs plus I should think). It started tripping the RCD on the consumer unit. I assumed I needed a new fridge and, to avoid repeatedly rebooting all equipment on the circuit while I sourced one, I plugged it in via a plug-in RCD. For space reasons this was into a different socket. It does not blow in the new socket...
Is it a fault in the fridge or the socket?
For space reasons I can only use the the plug-in RCD via an extension lead. (The "old" socket is awkward to get at because a kitchen unit has been installed in front of it.)
With fridge plugged into RCD into extension lead into "old" socket it trips the plug-in RCD between 1 and 5 times per week.
With fridge plugged into RCD into extension lead into "new" socket it works fine for at least 4 weeks.
The only difference between the two set ups is the routs of the extenssion lead from the RCD to the socket.
I don't want to buy a new fridge if it won't solve the problem (and using the "new"socket is not a long term solution).
Any advice gratefully recieved.
Tom.
Tom.
