G
goldenwonder89
1. The pitch supply circuits are separated toform an independent TT system to meet the requirements of Electricity Safety,Quality and Continuity Regulations (ESQCR).
a. The method used to determine the earthelectrode resistance for this system before a supply is available is.....
b. Following the text above in a. the earthelectrode resistance is determined from the test results obtained by.....
c. An alternative method to a. above, whoch maybe used to determine the resistance of an installation earth electrode whichforms part of the TT system where the installation is protected by an RCD, whenthe supply is available is
d. The maximum earth electrode resistance valuesfor each of the following RCD ratings are:
1. 30mA
2. 100mA
3. 300mA
4. 500mA
e. The maximum value above which BS7671recommends the earth electrode resistance may prove to be unstable is
1. 30mA
2. 100mA
3. 300mA
4. 500mA
