Discuss From a recent inspection in the UK Electrical Forum area at ElectriciansForums.net
The Bad old days Eh Lucien?, some of the Sov installs were DP fused, til I got my Mits on themAh yes, Kantark Minor, not Junior. GEC was Junior. I should be on top of this stuff.
DP fusing is usually now seen as some weird old dangerous practice, but when a lot of these pre-war DP boards were installed, the neutral was not guaranteed to be solidly earthed. An N-E fault could cause an overcurrent that would damage the N conductor unless it was also protected by a fuse. By the same token, a fitting could be live unless isolated in both poles, so there was little disadvantage to the DP fusing leaving a voltage to earth on a seemingly dead fitting if only the neutral fuse was open.
Reply to From a recent inspection in the UK Electrical Forum area at ElectriciansForums.net
