From a recent inspection | on ElectriciansForums
Discuss From a recent inspection in the UK Electrical Forum area at ElectriciansForums.net
Doomed
Dorset
[ElectriciansForums.net] From a recent inspection
I'm afraid your distribution boards are rather dated sir
(yes, rubber cables as well)
The channel fuses don't have flash pads because the fuse wire lies in the outward-facing channel. However, there is often a slot-in insulating partition between the line and neutral sides that is made of asbestos cement board. In this case I think it's missing. It's a 1920s pattern and probably the only board when first wired, usually located centrally e.g. in the hall behind the front room near the ground floor ceiling, fed from a switchfuse at the origin.
Where did you find ACMs in the 8-way board? Any detail pics? It looks like a MEM Kantark Junior board which doesn't have flash pads or asbestos tubes, the fuse wire being contained in a plain tunnel through the porcelain carrier. Larger MEM Kantark products with flat pins had flash pads, but not the 15A Junior. Obviously being SP+N it's much later than the channel fuses and actually pretty good as far as rewirable circuit protection goes. Their main hazard is the lack of touch-proofing of the end contacts.
The rubber is so flaky its a rewire recommendation, luckily its only now doing the lighting now (and 2 sockets wired in 1.0mm in one room), its just going to be awkward as its a functioning space open to the public except weekends and the flooring on all levels is one sheet of sealed lino stuff in each room, so there go goes what little social life I had if its accepted.
[automerge]1580668882[/automerge]
Both double-pole fused?
Lower one no, only live fusing, upper picture as I say I didn't dare disturb.
When the channel board was put in, there probably was only lighting, one circuit for each floor. The Kantark board probably fed a few 5A sockets too.
You'll need someone with some experience, of wiring old properties then Doomed, pick me up AM drop me off PM I'll give you a hand if you want. Got plenty of experience of drilling behind large cornices and deep skirting, no qualifications even the standard ones required for that sort of work, just lots of experience.
I'm impressed with your knowledge!
One 16mm feed from a 60A fuse in basement feeds the larger board at high level on the ground floor and then the smaller board at high level on the 1st floor, its a old building converted from residencial to commercial sometime after the 40's
The larger board has flash pads set into the board and surface mounted fuse wire on the carriers.
[automerge]1580669432[/automerge]
Would love too, but I think you are too far from me
Ah, OK it's regular Kantark then, rather than Kantark Junior, I thought I could see the end springs but apparently not.
Reply to From a recent inspection in the UK Electrical Forum area at ElectriciansForums.net
A small contracting company relies on word of mouth and good feedback / reviews. if you do work for 12 companies and have some spin off work from...
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
