DNS
Went to look at a CU change today. To be told the wall lights in the front room haven't worked for thirteen years. I thought check the lights first, otherwise the Rcd on a new CU would just keep tripping if there is a fault. Sure enough there were neutral faults. none of the wall lights in the living room had a neutral, sure, a Black wire was connected to each light, but they weren't neutrals??? Found a metal J/B unger the floorboards upstairs with 13 cables going into it, with a mass of choc blocks. see pictures. No identification/labeling. I labeled them A- K plus one feed, until I identified each wire. Took a while but got there in the end. These lights haven't worked for 13 years.....13 seems to be a connection here............excuse the punn.................They are all working now I found the faults. Hopefully now there should be no nuicanse tripping when done. The earthing arrangement was very suspect.......see pics.
