fronius ig-tl 3.6Kw startup time/voltage | on ElectriciansForums
Discuss fronius ig-tl 3.6Kw startup time/voltage in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
N
nbown
on my new system (3.92kw) and happy with it.
i have noted that is starts up when there plenty of light in the mornings, I think its to do with the start up voltage at 350v is there a way to kick the inverter off earlier in the say 300v.
I don't think you can and to be honest, I wouldn't bother. It shouldn't take much to get your panels up above 350v and whatever gain you had from lowering to 300v would be less than negligible.
Reply to fronius ig-tl 3.6Kw startup time/voltage in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hello Ric2013, MJPD29 and westward 10. I have a multimeter that I tested the voltage with and before I open the socket up I use a plug in tester...
Whatever... I awoke this morning ready for an intersting and relaxed day at work at my local branch of the Men's Shed charity. " jobs pending...
