G
Graeme Harrold
Just had a Sunday lunchtime call out to a new customer. Bought their property back in May as a holiday home, and have only just switched the heating on. Everything is fine, but come midnight when the economy 7 kicks in, everything goes dead when the RCD trips. I get round and do a quick visual and IR test on the econ 7 board and everything tests as it should. Moving back up-stream I get into the supply cupboard still scratching my head. Tracing the tails, we have L and N entering the meter with L and N departing for the RCD switch. L for the econ 7 leaves the meter via a henly (used as a joint only) off to the CU for the heaters. The supply N however is split at a henly after the RCD switch before going to the main CU and the econ 7 CU. This I explaind is where the inbalance was due to the fact the econ 7 was not being seen by the RCD, however the return N was causing the instintaneous tripping when current flowed.
The DNO have been out and changed the switch telling the customer it was faulty and I have told them to call them back out to sort it.
Im just seeking confirmation I got it right??
if the econ7 neutral is taken after the rcd then it will trip, as i think you said. the econ7 is taking live from the supply side of the rcd and neutral from the load side. huge inbalance
Superb peiece of fault finding top notch
Front End RCD Switch
Graeme Harrold,
Graeme Harrold,
