stratplus
Hi all, got a boiler in an unheated area with no pipe or frost stat. It's a combi boiler fed from a fused spur with a built in timer and separate room stat. How easy or hard would it be to fit a frost stat to this install?
Thanks in advance?
Hello all, I am after a bit of advice. I have a combi boiler in an unheated area. It has a built in mechanical programmer and a room stat. The boiler is fed from a switched fused spur.
How do I fit a frost stat to this system in laymans terms?
Thanks in advance?
