Fsu load to 2nd fsu supply in 2.5 | on ElectriciansForums
Discuss Fsu load to 2nd fsu supply in 2.5 in the UK Electrical Forum area at ElectriciansForums.net
Sheffield
Is this appropriate if off a ring final circuit and would testing just require testing the new cable installed. Both required for separate fixed Paxton access control unit boxes
A bit more of a detailed explanation of what your intentions are Mate would help considerably
am i right in thinking you mean RFC> 13 AMP FCU > sockets or just 2.5 Twin and Earth then another 13 AMP FCU??
Personally I have used a 13 amp rcd fcu recently to add a spur for an extra socket on a rfc and also then a fcu of this spur with 5 amp fuse for a 1kw heater in a small room that was once the downstairs toilet. there were no rcds present so it provided the easiest way to acheive the desired outcome.
I have seen quite a few posts in the last two to three days which are very difficult to understand. The posts concerned either get trashed or no replies. My advice to to re-write the whole opening post again so we English speaking Electricians can try to assist you.
Still waiting for a reply here, if you ask a question please see the thread through, I have no intention to be sarcastic or nasty, but you asked a question, and have not been back since.
Reply to Fsu load to 2nd fsu supply in 2.5 in the UK Electrical Forum area at ElectriciansForums.net
Yes, probably overthinkig, thanks.
Ah! but thats where I have found cross polarity when doing an EICR (twice in about 20 years and thousands of tests......)
2 3
5K
Recommended Sponsor News
thanks for the clarification. ( also thanks to Dan. ).
More info on link below http://sbsc.uk.net/
9K
Happy Friday Everyone! Subscribe for more jokes direct to your mailbox or send us your own jokes to be in with a chance of featuring, by clicking...
6K
