switched on
hi i am a newly qualiied electrician doing an install at the moment where dno have brought there supply to the outside box. i was going to drill through the wall and put the fuseboard on the adjacent side. Is there a height regulation on the fuseboard i thought that it just had to be accessible?? i obviously know i will have to put my tails through conduit through the wall. The other question is if they want the fuseboard in another location more than 3 m away from the origin i would run a split with a 100 fuse switch but could i locate this in the box outside?? thanks in advance
