J
Jake.
Trying to get a 2001 Renault Clio started but the fuel pump won't run.
When I turn the ignition on I can measure 12v for a second or so at the fuel pump plug. But the pump doesn't prime or do anything. I believe it should run the pump for a second or so to pressurise the the fuel rail, and then run the fuel pump full time once the ecu detects RPMs.
If I bridge the fuel pump relay I can measure a constant 12v at the fuel pump plug - but the fuel pump still doesn't do anything.
I've bought another fuel pump and fuel pump hanger assembly but still the same problem.
With one wire going from the positive side of the fuel pump plug to the pump and one test wire from the Neg battery terminal to the pump; the pump doesn't run.
But the other way around; a wire from the negative side of the fuel pump plug and a wire from the Positive battery terminal = the pump runs.
So, does this mean that, even though there is 12.5v at the fuel pump plug, the positive wire has a bad connection or a break somewhere?
From my research on the internet I understand that the Fuel Pump Relay switches to connect and disconnect the negative side of the circuit. So if I run a new positive wire to the fuel pump should I be OK to run it directly from the battery, or is it more complicated than that?
Thank you !
Thank you !
