Oh yes, this is my first post. Be as kind as you wish ;-)
I'm maintaining a building and found a white fungus on the outer sheath of tails within a metal enclosure and a 3-phase switchfuse. I'm wondering if it's something to be concerned about; I presume it's a result of humidity since the cupboard had been used to store cleaning materials (probably including wet cloths or mops) and this is in a basement that has flooded due to leaks and a burst main water pipe. It's been through the wars!
To put it into perspective I've drawn the installation, with the lid removed off the enclosure below the meter, which contains the DNO cut-out fuses and neutral block. And I assure you, it doesn't look anywhere near as neat as this:
And here is the fungus inside the large switchfuse in the bottom-left of the diagram:
And here within the enclosure below the meter:
So, wise ones, is this something I should be concerned about, aside from the obvious concerns over health from fungus spores?
If you look back at the diagram, the incomer is MI and those red-sheathed tails that run to the 3P 60A switchfuse run through a short length of steel conduit. Inside the enclosure, the fungus almost seems to grow out of (or into) the entry point of the conduit. It has inspection elbows but I haven't opened it up so as not to make any airborne spores worse if the thing is just a big furry mess inside, but the conduit is clearly corroded showing signs of uninhibited moisture ingress.
It's certainly not something I see every day, so I'd appreciate some feedback. Cheers!
