Fuse board protection against fire | Page 2 | on ElectriciansForums
Discuss Fuse board protection against fire in the UK Electrical Forum area at ElectriciansForums.net
Hounslow
Hi guys interested to know what people on here use to keep the fire integrity off the fuse board for rear entry cable entering the board. Thanks
Problem would exist if fast fix boxes hadn't been invented. Horrible things, I've only ever used as a last resort.
You used to be able to get proper 35mm metal boxes with 'wings' at the side, that went behind the plasterboard, and a threaded hole in the back of the box that you fitted with an appropriate length 3.5mm screw to push against a piece of wood glued to the inside of the opposite board of the wall.
useless grommet strip
For large holes which are basically rectangular, even if the corners are radiused
[ElectriciansForums.net] Fuse board protection against fire
I've found that that plastic slide binding strip (e.g. Coloured Plastic Slide Binders - https://www.printfinishingsuperstore.co.uk/coloured-plastic-slide-binders-299-c.asp ) works well.
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
Reply to Fuse board protection against fire in the UK Electrical Forum area at ElectriciansForums.net
  • Solved
Please use the like button to thank, like or whatever. As the forum treats that as a positive message then and uses it to score members.
    • Optimistic
It's nice when people box off a big blank canvas like this. Makes a change from being asked to perform the impossible and expecting cables be...
nicebutdim
N
