P
paul161
What check will be carried out with the Fuse test on a PAT Tester?
Is it Polarity?
Is it Polarity?
Discuss Fuse botton on PAT Tester in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
How can the Pat tester, test for appropriate rating?
To give the OP the benefit of the doubt, specs for some machines do state that they do a fuse check and a fuse test
check the blurb here
quote ........Tests available from the KT75: Fuse Test, Fuse Check (on front panel)....
Reply to Fuse botton on PAT Tester in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
