R
rattlehead85
Carrying out an inspection on a victorian style Multiple occupancy house split into 4 flats. Each flat is wired in 10mm2 bare pyro clipped direct with and estimated draw of 30A. max run approx 35m. Each flat is protected at intake source Ryefield by a 100A 3036 porcelain fuse.
I have classed this a C2 as i am sure the cable under these conditions needs to be 25mm2 and not 10mm2 or the 3036 downrated to 60A to coincide with the existing 10mm2. Can anybody confirm this. I have performed a cable calc but would appreciate a second opinion.
Thanx.
Thanx.
