C
chipavatar
Hi guys,
Just wondering if anyone could advise me.
I purchased this 6 way switch box from eBay. It has a T5 Amp Anti-Surge 20x5mm fuse fitted in the switch box itself, however I was wondering what fuse should I use for the incoming mains (it will be connected via a plug socket in the house with an RCD).
In the instructions it says "If the product is connected to the house supply by a 13Amp plug no notification is required to the local building inspector", but as I'm only going to be running low power things from the switch box (such as pond pumps and equipment) which would generally use a 3 amp fuse, I wanted to check if a 13 amp fuse is the correct fuse to use for the incoming mains supply (baring in mind there is a T5 Amp Anti-Surge 20x5mm fuse fitted in the switch box itself.
