fuse panel | on ElectriciansForums
Discuss fuse panel in the UK Electrical Forum area at ElectriciansForums.net
M
michael_brooke
Hi guys
Ive come across a panel while testing on communal flats and this panel holds at least 24 60amp fuses which supplys each flat db what is the name of this panel and how do i include this panel in a test sheet, help would be appreciated.
[ElectriciansForums.net] fuse panel
something like this, but bigger?
Reply to fuse panel in the UK Electrical Forum area at ElectriciansForums.net
Obviously you need to check the means of earthing, Ze, and polarity no matter what for the EIC. As above, if anything looks dodgy then EICR is a...
How did it go?
