Discuss fuse rating or setting in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Should be clearly stated on the device or in the case of a variable device like an Mccb it's asking what rating the arrow is pointing at.
Ive searched but cant find any info on the following-
On the certs forms
under main switch or circuit breaker it asks
Fuse /device rating or setting??:santa_cheesy:
Please put me out of my misery by telling me your secret.
How in God's name did you manage to pass C&G 2391 ????
Naaa. Surely not! Really? 2391? Naaa, you're kidding aren't you?
Look, I'm crawling back to the Arms again. Would someone please be kind enough to kive me a kick at closing time?
in general, esp. domestic, it will be a D/P main switch with no overcurrent device and so you would enter the current rating e.g. 80A, 100A. don't forget, this is just it's max. operating current. in the case of the isolator incorporating a MCB/Fuse, then you enter the In for that device.
Go on the iet web site and you will come across the name John Pec.... he writes many posts & teaches it at evening college. To be honest the 30% pass rate is only down to not enough intellect i found it quite easy. He was also in the police force i believe.
I've got an RCD an RCCB & 60947-3 here and neither states the breaking capacity on them, why would that be?
In:-
I is amps, can't remember what n is?
Thanks for the helpful and reply's.
In:-
You've apparantly done the 2391 (and easily passed) so why don't you go and look through all the notes you have from when you took the course, and find out the answer to what 'n' is?
Instead of, yet again, wanting people to wipe your arse for you.
Am i the only one thinking (with a degree of confidence) that this person is a wind up? Reg's im really not convinced by your legitimacy and for that reason i will never comment directly to you again, sorry if i've got the wrong end of the stick but really don't think i have.
Reply to fuse rating or setting in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
