Fuse Type | on ElectriciansForums
Discuss Fuse Type in the Australia area at ElectriciansForums.net
P
Penfield
Hi,
Does anyone know what Type this fuse is and what the Short Circuit Capacity is? It's the main incoming isolating device and I need to know what type and scc it is for the installation certificate. The only info on it is stamped on the front of the fuse as seen in the pic. I've tried googling but keep going around in circles.
  • [ElectriciansForums.net] Fuse Type
Reply to Fuse Type in the Australia area at ElectriciansForums.net
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
Nothing wrong with it. Which manufacturers have you got this information from? What do you mean by trip speed? Fuses and MCBs can operate in the...
davesparks
