Stuuk1
Hi again,
I have already posted this tagged on to the end of a previous thread but don't think anyone saw it so posting it in a brand new thread.
I'm buying a new house very shortly and her is a big question I have!
The incommer to the house is one of those on the outside wall with a door for access.
The existing disboard is within 3 meters of that in what can only be described as a ridiculous place and not where I will be wanting the new one installed, it is directly above the front door boxed in with little cut outs for access to the main switch and the rewireable fuses...
Am I able to install a double pole 100A (or whatever size the incoming head fuses are) breaker and then wire away in 25mm cabling contained in plastic copex approx 10 meters to the cupboard under the stairs? I've asked a few people and they all said 'cant see why not' but at the same time weren't sure!
The copex would be routed from this breaker (which would obviously be accessible and within 3 meters from the head) under the 1st floor floorboards to the cupboard.
Thanks in advance!
Thanks in advance!
