Fused connection unit mounted on metal backbox | on ElectriciansForums
Discuss Fused connection unit mounted on metal backbox in the DIY Electrical Advice area at ElectriciansForums.net
Peterborough
greetings :)
I’m taking a spur from a ring final.
A fused connection unit will be controlling the spur.
FCU will be mounted on a metal backbox flush in a brick wall.
I’m planning on using a junction box to break into the RFC, and taking the spur cable to the FCU.
My question is, do both cables going to and from the FCU have to be in the same hole in the back-box, or can I have each cable in a different hole?
Thanks,
Gary
Whichever is best for the physical constraints of installation. What's your thinking behind this question ?
why not just install 1 cable from JB to the FCU?
As there isn’t much room for both cables to go through the one hole, and putting a rubber grommet in there for both is a right pain in the proverbial, so I decided that one cable in each would easier :)
Telectrix, apologies for my not being very clear, I wasn’t quite awake when I typed it There will be one cable coming from the junction box to the FCU, and another coming from the FCU to supply the spur dependants
Thanks for the replies!
i never have any trouble fitting 2 x 2.5mm cables through a 20mm hole with grommet. but no problem in using separate holes if that's your preference. ( cost you an extra grommet though. :().
[ElectriciansForums.net] Fused connection unit mounted on metal backbox
are there any other types?
That will need to be accessible to testing in the future. You would be better off using a maintenance free junction box, such as a Wagobox with appropriately sized and rated Wago connectors.
Or Hager do some nice maintenance free boxes.
Basically anything with a screw terminal needs to be accessible for test and inspection as over time, thermal cycling can cause the termination to loosen. Loose terminals = fire risk.
Yup, I’ve made a section of the floorboards liftable where the junction box is located :) nice and easy to get to
Why complicate your life (and more importantly the next owners of the property). Do it properly in the first place and use a maintenance free junction box.
Reply to Fused connection unit mounted on metal backbox in the DIY Electrical Advice area at ElectriciansForums.net
An example of the long term race to the bottom of quality of work in our industry, IMHO.
I think I've found the answers to my questions... I can just do a straight forward wiring i.e. connect the 3 wires from the armoured cable to...
