house consumer unit has no rcd !!!! tn cs earth system
job description
power to garden pump !!
option 1
fused rcd spur fed from indoor socket through wall to Ip56 junction box on out side wall
from there swa 1.5 mm burried 500mm in ground for distance of 26mts then terminated in to ip56 2 gang socket
option 2
normal fused spur fed from indoor socket through wall to ip56 junction boxon out side wall from there 1.5mm swa buried 500mm in ground for a distance of 26 mts then terminated in to a 1p56 rated 2 way consumer unit with rcd ( i am lead to believe swa does not require rcd protection )
will these comply with minor works evn though its notifiable
also because of the earth differensal would the the 2 way consumer unit need to be tt and the earth not terminated at the 2 way consumer end from spur
there is no spare ways in db1 and i do not want to disturb ring final circuits and no room to split tails
i would interested to know how other sparks dealing with these sort of jobs
all responses would be gratefully received
Rich
job description
option 1
option 2
Rich
