I'm sure this question has been asked to death, so apologies! But just wanted some direct confirmation that my intended wiring setup is going to be completely fine/not fine.
I'm currently planning on having my combi boiler relocated to a kitchen cupboard prior to a kitchen remodel. There is no supply running to the kitchen cupboard, or anywhere along the kitchen wall where the cupboard is situated.
In the bedroom (directly behind said kitchen wall) I have spurred a socket from the ring main onto the opposite side of the wall where the cupboard is situated. I'll only be using this socket for relatively low-draw devices (Amazon Echo, USB charger, etc)
My plan is to supply the fused spur for the boiler from the existing spur in the bedroom.
I'm aware that spurring off a spur is generally a big no-no due to the risk of overloading the supply cable, however as the spur for the boiler is fused and the spur it is feeding from will be under relatively low load, would this be feasible?
- TL;DR
- Can I attach a fused spur for a combi boiler to an existing spur?
