fused spur from a spur | on ElectriciansForums
Discuss fused spur from a spur in the UK Electrical Forum area at ElectriciansForums.net
dim_bulb
good evening,
brain has gone walkabouts tonight
can i put a 13amp switch fused spur from a spur i.e
sockets ring main - spur- switched spur?
the load is only a t.v nothing heavy
alternative would put the swicth fuse in before the spur, then spur off the spur but like to avoid as decorated house
its all rcd etc.
thanks
if its fcu first then you can have as many sockets as youd like. if the spur is feeding a socket then that has to be end of the line. regardless of load theres potential for overloading the cable.
Putting the fcu after the spur would be just the same as adding another socket so a no no, can it not go by the side of the spur and go to that first then you can add sockets til your hearts content, or the fuse blows, one of the two, or by the side of the socket its spurred from
Reply to fused spur from a spur in the UK Electrical Forum area at ElectriciansForums.net
K
Ah, I see. The op question is ambiguous, and I took it that he wanted to add a socket for a washing machine from and exiting switch fused spur. A...
It depends on where that SFU 'sits' in the circuit. If it's there as a courtesy isolator for the fridge socket then potentially yes as it could...
