Builder installed 175w / sq metre in an area 6.7 x 3.5. What should the fused spur be rated at and should it have a contractor as well?
Am I correct in thinking it is drawing just over 17A therefore 13A fused spur is insufficient?
Is the spur (aka FCU) getting warm? I would probably switch it off until you have got to the bottom of things.
Its 175W per sqm therefore you have to multiply the mat area by 175W thats why I asked it the area he quoted was the mat size or the size of the room.
6.7 x 3.5 = 23.45
23.45 x 175 = 4.1kW
4.1kW / 240 = approx 17A
Depending, as Mike said, whether this is mat size or room area.
OP, is the FCU ('spur') warm?
ask when he's taken the washing off of it.
2 cats shat on 2 mats.
stapled their tails together. Siamese cats. ?
We have not heard back from the OP on the size of the mat or room, everything else is guess work, including how many cats are sat on the mat.
and a roll of A4 paper to print off the lecy
6.7 x 3.5 = 23.45
23.45 x 175 = 4.1kW
Thanks everyone, that was the room size....the problem was the fuse was blown and casing burnt...checked with the builder who installed it and the fused spur should have been 20A, but the matting is slightly under the size I quoted making it just under 16A which works for the Stat (but not clearly for the switch).
Thanks everyone, that was the room size....the problem was the fuse was blown and casing burnt...checked with the builder who installed it and the fused spur should have been 20A, but the meeting is slightly under the size I quoted making it just under 16A which works for the Stat (but not clearly for the switch).
I think you need to get your builder to pay for an electrician to put this right. And point out to him what he has done wrong - I bet he's done this in other properties as well.
Is there any fixed furniture in the room now, if this furniture is on top of the mat this would cause localised heating and lead to a short circuit and blowing of the FCU, lots of variables that can not be ascertained from your posts.
What is the room used for?
Buckinghamshire
United Kingdom
Fused spur rating for electric underfloor heating
Central Heating Systems
HenryCooper,
Timbo,
