Fused Spurs for Kitchen Appliances hidden in cupboard?? | on ElectriciansForums
Discuss Fused Spurs for Kitchen Appliances hidden in cupboard?? in the UK Electrical Forum area at ElectriciansForums.net
sparkyjohn1
Just wondering if anyone can shed any light on this Topic, as i have had conflicting opinions from a few sparks..
Is there any Regulations as to where fused spurs for appliances should be,, (ie, so far from each appliance..)?. I know they should be accessible and not obstructed.. I have fitted the 'grid switch system' before with 4 appliances fed from it. But recently came across this Installation,,, it has 7 fused spurs, and one single socket outlet.. Closer inspection, it was a ring, fed by 2 x 2.5 tails back to c/u 32 amp breaker.
Also Note the 2 cooker Isolators next to them,, For Cooker and Induction Hob,, Fed by 6mm and 10mm respectively.
There is a guideline stating cooker Isolators should be 2 meters from appliance,, but is only a recommendation,?!
I know the picture isn't an ideal way of Installation, but would it be acceptable? Is there anything wrong with it??
by the way, Fused spurs are for.. Fridge, Washing Machine, Dish Washer, Tumble Dryer, Extractor fan, Intergrated Microwave, and Heater in the kickboard plinth. Any feedback would be appreciated. thanks
[ElectriciansForums.net] Fused Spurs for Kitchen Appliances  hidden in cupboard??
Fused spurs
Re: Fused spurs
Now close your eyes and imagine for a moment, that cupboard full of pots pans and other junk!! Then tell me that ALL these switches/FCU'S are going to be readily/easily accessible in the future!!!
Why the hell everything has to be hidden away out of sight these days, is beyond my understanding!! All it achieves, is a kitchen that that can't actually be used as a kitchen, it just looks nice!! lol!!
Now close your eyes and imagine for a moment, that cupboard full of pots pans and other junk!! Then tell me that ALL these switches/FCU'S are going to be readily/easily accessible in the future!!! Only a bloody idiot would install these isolating switches at that level and at that depth!!
Better than all on show above your work top lol
NO it's not!! thats exactly where most of these controlling wall accessories should be!!​
I had this "discussion" with a customer a while ago.
I wanted the switches above the worktop where they could be reached and she wanted them on the back wall of the cupboard underneath the worktop where they would be hard to get at "like the other electrician did".
I told her I'm not the other electrician.
With all that switchgear it would have been no more work to install a sub-db and run all circs as radials from it - possibly located above this cupboard below coving (just as accessible when compared to a cupboard full of junk).
The other problem with 'hiding' switchgear in cupboards like this is that you are also concealing cable runs (re safe zones and diy drilling).
Modern kitchen are now more like bloody showrooms than a homes domestic working area. Look nice, but can no longer function as a family kitchen should be able too. .....And if something or a switch/outlet stops working, or needs looking at, half the kitchen cabinets contents ends up on the kitchen floor.
Reply to Fused Spurs for Kitchen Appliances hidden in cupboard?? in the UK Electrical Forum area at ElectriciansForums.net
It can be easy to lose the sequence of things. If the fused spur has a neon indicator and this isn’t coming on then I wonder if -the original...
Ask your electrician when they do a site visit as to what is required they can also notify the installation to Building Control under Part P of...
