Fused spurs | on ElectriciansForums
Discuss Fused spurs in the Australia area at ElectriciansForums.net
J
Jelj360
Morning Fellas,
If you run a spur from an FCU on the ring, can it feed a double socket- then from there to another FCU and from there to a single light and switch?:confused:
As long as you feed from the fused side of the FCU on the ring, not the unfused side. Sounds obvious, but I have seen it done many times by John Wayne and the lone rangers, particularly in kitchens and conservatory wiring.
A spur cannot be spurred off the live side of a spur.
Reply to Fused spurs in the Australia area at ElectriciansForums.net
K
Ah, I see. The op question is ambiguous, and I took it that he wanted to add a socket for a washing machine from and exiting switch fused spur. A...
It can be easy to lose the sequence of things. If the fused spur has a neon indicator and this isn’t coming on then I wonder if -the original...
