G24 replacement and ballast query | on ElectriciansForums
Discuss G24 replacement and ballast query in the DIY Electrical Advice area at ElectriciansForums.net
Jwatson
Manchester
Hi guys
Moved into a new place this year and have a g24 4 pin light fitting in the storage cupboard. Light recently went and I've tried two new bulbs but just get a flicker. Seems there should be a ballast to replace but I can't find one and assume this is part of the overall compact fitting? There is only live and neutral running into the fitting from the ceiling rose.
If that's the case can I simply change the entire fitting for a standard E27 or do I have a hidden ballast somewhere?
Thanks for the help. Image of the fitting and above in the ceiling.
  • [ElectriciansForums.net] G24 replacement and ballast query
Reply to G24 replacement and ballast query in the DIY Electrical Advice area at ElectriciansForums.net
For my hapeneth and learnt from hard recent experience, the term LED transformer and driver tend to be used interchangeably, when they are...
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
