g9 bulb (ceiling fitting flush) Heat problems | on ElectriciansForums
Discuss g9 bulb (ceiling fitting flush) Heat problems in the UK Electrical Forum area at ElectriciansForums.net
hello all
in a 230mm diameter flush ceiling fitting does anyone think a g9 bulb will create enough heat to possibly damage the wiring enclosed above im pretty sure it wont as no heat sheathing was provided for the light fitting wiring just wondered how much heat these bulbs produce.
Read more: http://www.electriciansforums.net/e...tting-choc-block-enclosure.html#ixzz20tnqgYQz
The light fitting is presumably designed to have this wiring above it as there sounds like there is little space for it to go elsewhere, so it should be OK. However if you are worried then applying heat resistant sleeving over the wiring should mitigate the effects.
Reply to g9 bulb (ceiling fitting flush) Heat problems in the UK Electrical Forum area at ElectriciansForums.net
