Galaxy 144 alarm system | on ElectriciansForums
Discuss Galaxy 144 alarm system in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
J
Jak1708
Hi all
I have a Honeywell galaxy 3-144c main alarm board and want to connect an external sounder and strobe unit to it,
The sounder has the following connections :
V+
V-
Sw-
R-
St-
But the panel has nothing that matches these ?
Can anyone help?
Jack
not familiar with the galaxy, but it will have a set of bell terminals. a pic of the pcb would help.
I'm guessing first 2 will be perm pos & neg, Sw will be switched negative for the sounder, R tamper return and St the strobe negative. You may have to pair up the strobe positive with V+
Regards
As you can see there is nothing with bell marked on it
However there is an external sounder point so wondering if that's it ?
thought that. but i.m not sure. if so , V+ to +, SW- to -, V- and R- to the tamper terminals.not sure about ST ( strobe)
If I remember correctly, On a G3 ....
V+ = positive
V- = Negative
R = Tamper return 0 v
OPT 1 Bells
OPT 2 Strobe
I think these panels used the on board outputs for Bell and Strobe where you can program them in Option 53
The smaller G2 s had dedicated bell and strobe terminals.
Thank you !!
Wired in a panic alarm to a spare zone as well but new to get into the engineer zone setup to set it as a panic alarm so it's constantly monitored instead of just when the alarm is armed but it says "insufficient acces rights" I've got the master code and can select to turn on the engineer access but no code works ??
I've tried 12345, 1234, 4321, 54321, 9090, 9999,
Anyone know how to do this ?
Jack
Best thing to do then if you don't know the master code is to pop out the watch battery on board to default.
Then it's 12345
enter 48 then enable engineer access.
Then default eng code is 112233
Timbobelfast thank you so much you were spot on, managed to set zone 3 as PA,
Wired blue to "zone 3" and one side of the pa terminal and wired white to "0v" and to the other side of terminal, pressed button and nothing :(
Any ideas ? Or test I can do ?
Thanks again !!!!
Well in PA devices as in all devices to be connected to galaxy panels they work on resistance. Some PA buttons have pre-selectable resistor jumpers in them and others you have to fit in the resistors yourself. Check if it has the resistor selectors. You want a 1k for for closed and 2k for open. If you have to fit resistors normally galaxy panels come with a bag of them they also come with 3k and 12k so be careful you get the correct ones. should have two black and a red band on the resistor. Anyway I have included a little diagram and I am no picasso. But is shows how it works.
[ElectriciansForums.net] Galaxy 144 alarm system
Also not sure if you are aware but if you go to menu option "21" Display Zones you can view your circuit number and if you press the # key you can view the zone resistance. If it shows 1000 Ohms or there about then the zone is closed that is what you would expect to see when the zone is NOT triggered. if you trigger it you should see the resistance go unto 2000 Ohms or there about. If it shows Tamp S/C with a low ohm reading then you have got a short somewhere or it is incorrectly connected. If you see Tamp O/C it means there is a break or it is incorrectly connected. Also another thing about configuring the PA button in option "52" you can set it to either PA or PA Silent. the difference is almost explanatory PA will trigger the sounders which in some situations will alert the whoever is around something happening while PA silent will not activate sounders but will trigger the dialler outputs.
Also in regards to the bell/sounder some require a 1k resistor fitted between the +V hold-off and the Bell trigger terminals inside the bell.
Thanks all ,
Im getting a panic alarm from Elmdene who I believe have the resistors already set up for a galaxy board
Hopefully that does it
The new Elmdene PA buttons are now all fitted with resistor selectors in them with various jumper setting positions for your pleasure and they dont have the old annoying screw terminals they are micro switches with block terminals. Took them long enough :p
Hi Jack, just seen your question. You can connect as follows: V+ to + on panel PCB, V- to 0V on panel PCB, R- to TAMP return on panel PCB and R- to BELL out on panel PCB. This should work. regards, Bernard
Reply to Galaxy 144 alarm system in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
These keypads are obsolete and replacements are hard to find, I've replaced loads now with failing displays. Sounds like something isn't...
Seen this where T&E has been fixed with a flat bend of too tight a radius.
2 3
