Galaxy G2-12 Unset from Keypad | on ElectriciansForums
Discuss Galaxy G2-12 Unset from Keypad in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Sc00by121
UK
Hello,
I have installed a Galaxy G2-12, one door contact, one PIR. Very simple set up and it all works fine however it won't unset from the keypad.
I see reference to 'Restrict Keypad' in the manual and see that the default is to require a single unset like a keyfob. I don't have keyfobs and need the panel to unset.
However my problem is that the menu does not tie in with the manual
It says in engineer mode go to item 51 (parameters) and then to 55 (DD243) and then 3 (restrict keypad) and then 0 for No.
I go to 51 but 55 says NOT USED.
Can anyone advise, I've been digging around the menu in depth and cannot find any reference to DD242 or Restrict Keypad
Cancel that, I found it. I actually found a small addendum slip in the box about this exact setting which differs from the main manual. Completely different name and location within the menu. I must be on a different firmware version.
All working great now.
Reply to Galaxy G2-12 Unset from Keypad in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
