Galv lighting trunking | on ElectriciansForums
Discuss Galv lighting trunking in the UK Electrical Forum area at ElectriciansForums.net
suffolk
I'm currently doing some galv lighting trunking all wired in low smoke singles with metal fire clips installed in the trunking over the escape route. I have been supplied plastic lid by the main contractor is there any thing in regs about not being able to use this. Sorry would look in my byb but as working away and traveled with someone else it's a bit hard when it's at home I really appreciate your help stu
Sent from my iPhone using Tapatalk
Don't know any reason why you cant use plastic lid as long has you have the metal retaining clips so the cables dont full out if the lid was to melt , afterall you can still use yt2 amd yt 4 plastic mini trunking as long as you use the retainging clips, unles metal lid has been specified by the designer.
Galv trunking should have a galv lid?. Think I have seen it many years ago.Nothing wrong with using plastic and singles either, the only concern I would have, no mechanical protection with plastic maybe not even with a lid?, what is the environment and situation of use.
Just didn't know if there was anything to say about the plastic lid on it falling and causing a hazard but I guess I'm just over thinking this as the light fittings are plastic back all though held on by clips I'm sure a plastic light melting and hanging is more of a hazard then a 1,5 m bit of plastic lid
All lighting trunking i have installed has had plastic lid , athough i have seen metal lid in the past
You should also consider whether the PVC lid is flame propagating and whether it would release toxic fumes.
I would far prefer to see galvanised lid to be honest.
I don't see the relevance unless the designer has spec'd metal.
It's going to be full of PVC singles isn't it?
Reply to Galv lighting trunking in the UK Electrical Forum area at ElectriciansForums.net
Hi I'm again struggling with a long overdue 2396 project but, as before, am at a standstill when it comes to the lighting design. Please could...
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
