E
eds54
Hi All
Has anybody had a problem or even heard of Galvanic Corrosion. A house that was completed 2 years ago has started having water leaks. (I know this is a site for electricians) a water softener was recently fitted and the manufacturers have suggested that because the plumber has used a mixture of copper and plastic pipe there is no earth continuity throughout the pipes and possibly causing Galvanic Corrosion where the 2 join. Has anybody had this problem before an if so was there a solution other than cross bonding across the joints which I imagine even if the plumber could remember where they were would be a nightmare. I have never heard of this happening before so any help would be appreciated.
