G
gregorabbott
hi folks, you have probably been asked this many times but any ideas the best way to avoid nuisance tripping? i am running power to a garage using 10 mm swa, the garage is about 25m away from the main fuseboard which is a wylex all rcbo's with 1 spare way. i am then taking power to a shed from the garage using 6mm swa. the shed is about 20m away from garage. the swa will be buried underground. best way to avoid nuisance tripping?
