Hi All
I'm in the process of getting quotes to get an EV Charger installed, and hopefully at the same time power to 14 residents garages. As it stands, the expectation is the majority of use in the garages will simply be for lights as they are too small for modern cars. There will undoubtedly be exception to this but the intention is to limit each garage with a 16a RCD (and also a small kwh meter for usage measurements).
Our building has a 3 phase feed and we appear to have a spare 60A DO. If i were to get a meter installed for this circuit, would you consider this enough capacity for a 7kwh charger as well as the garage supplies? In the future we will no doubt need to upgrade the charger given demand is likely to go up at which point I imagined getting a 3 phase system installed and therefore free up more capacity to the garages which I have a suspicion may start to become more useful as small offices, gyms etc if we allow it in the leases.
I am of course not unteraking this work myself but just want to get some additional opinions from you fine folks
Cheers
C
Cheers
C
