T
timo
If the house has a garage and its fed from a 32A MCB in the main CU via a SWA to its own 2 or 4 way CU in the garage itself. Would the test results for the SWA supply go on the main results sheet and the garage on its own certificate ? Or maybe a break at the bottom on the results sheet by a few spaces and then the garages results added?
Just wondering how others are doing these
Also would you ZE and PFC from the garage main switch and record these as seperate on the results or would the main C.U ZE / PFC act for these circuits.
